DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Mon Jul 04, 2005 8:09 am
absolutely, also you only bent one valve? lucky bastard. anywho, you failed to mention if you had the valve you purchased cut for the head. that valve may never seal quite right.
Definately recheck your cam timing before you try to figre it up too many times unless you worship bent valves
