SaletOn4Wheels wrote:I should have said tht but yes the $1800 is for a out tear down and back in, but thats still $1800 with out fixing anything. And no I haven't done any of the compression tests with oil etc and I'm not sure hoe Mr. Ramey did it when he did it either. And no I dont think theres coolant in the oil, last time I changed the oil it didnt look very milky but I guess i could check it again..
Knowing that it's a pull, tear down, rebuild and install, $1800 is a good price. I agree on that with Z-owned. I like the items Brett Ramey he has designed for the Z motor. I have a couple of things for my Z that he sells (idler pulley studs and sling). So, it's obvious he understands the motor and even how to improve it's reliability. I would trust him.
I think you need to understand something about your Z. It's not a Honda. The motor is complex and takes skill and patience to repair. The cost isn't determined by your wallet, but by the complexity of this motor. So, the amount of labor he is charging is reasonable to cheap. I wouldn't do that amount of work for $1800. With parts, you are looking at around $2.5k-$3.5k (without turbos). That is a good price for a fresh motor. If you look at Z1 and what their short blocks sell for, you can spend $2800 for just the short block, plus gaskets, plus labor to build the motor and installation. Unfortunately, many buy this car and never consider the amount of money it takes to keep it in good repair. I do all my own work. It's the only way I can afford to keep it and I have a good job.
The only way to avoid this kind of expense is to do the work yourself. If you don't have the expertise, then pay an expert and get the job done right.
