Low compression...thoughts?
nissanman04
Car: '90 240SX, '95 Subaru Legacy
So I tried to start my S14 the other day. It cranked, but it wouldn't fire. I thought this was weird, since I experienced no problems the last time I drove it. It had only been sitting for two days, maybe not even. I pulled the spark plugs today, they all smelled like fuel. I cranked it over and saw that I had spark, too. So now that I know I have fuel and spark, the only thing that could be causing the issue would be low compression/timing issue. I did a cold compression test (yeah, not the most accurate, but if I could do a warm compressions test, I wouldn't be making this post) and I got 70, 60, 80 and 140 psi from cylinders 1-4 respectively. I thought maybe the gauge wasn't sealing right, but I tested two cylinders on my S13 and got about 185 psi for both. Could I possibly have jumped a tooth on the timing chain? I have no signs of head gasket leakage, and it seems weird for the rings to be fine one day and be that bad the next day. Any thoughts?
airman86
pour a little bit of oil into each cylinder and run the compression test again. if the compression doesn't change, then you either have a borked head gasket or bent valves. if the compression ratio gets a lot better (probably 120 or 130+) you're probably looking at rebuilding it because that shows your rings are bad.
Modified by airman86 at 8:23 PM 4/2/2009
nissanman04
airman86 wrote:pour a little bit of oil into each cylinder and run the compression test again. if the compression doesn't change, then you either have a borked head gasket or bent valves. if the compression ratio gets a lot better (probably 120 or 130+) you're probably looking at rebuilding it because that shows your rings are bad.
Thanks...that was my plan for the weekend
ZOMG.SR20
Car: 1990 s13
try a leakdown test it saved me alot of headache
carkook
Yeah sounds like your educated enough to figure out what went wrong, anything im going to tell im sure you have already thought about and planned to do. But anyway, heres my thoughts, since cylinder #4 did get such a higher compression, I doubt the cam timing was off. My guess is that it got hot with out you knowing and blew the headgasket/warped the head.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
i blew a fuel pump relay and had no idea till i tried to start my car the next day and all it did was turn over. check your fuses and relays under the hood, use a test lamp. hope its something simple.
pearl1996zenki
Car: 1996 240sx
CHECK FUSES, BATTERY, DISTRIBUTOR TIMEING. JUST TRYING TO HELP
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
pearl1996zenki wrote:CHECK FUSES, BATTERY, DISTRIBUTOR TIMEING. JUST TRYING TO HELP
No you're not, you're just trying to get your 10 posts.
nissanman04
So I finally got around to investigating the cause of the problem. I did a leakdown test and the air was obviously escaping through the valves. OK, so something had to go wrong with the timing somehow. I pull the valve cover and at TDC, the cams looked a bit more advanced than they should, but there was nothing out of the ordinary with the upper chain assembly. I took off the upper timing cover, and I believe I have found the problem:
It seems that the lower chain jumped a tooth or two. I plan on pulling the engine (easier access, and this car is not my DD anymore) to see how much damage there was. Hopefully I can just replace the timing chain components and be all set. If I bent valves, I'll be looking for another engine.
carkook
Its a constant game of pistons chasing valves, hopefully none were bent. Keep updating interested in seeing. At least theres hard evedince on your car like that timing issue. A collapsed lifter ended up causing one of the exhuast valve seats to be damagaed, took forever to figure that one out.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
nissanman04 wrote: If I bent valves, I'll be looking for another engine.
Don't be a pansy a**.I just got done rebuilding my head literally 5 minutes ago.It's easy as hell, and if you really want I can do a writeup on it.
carkook
Just fine another head and slap that baby on there!
dreek96max
Car: 96 Maxima VQ30DET
93 240 SR20DET
whatsup s13crazy do you mind doin a write up on the head rebuild...I tried to add you as a friend but dont see how
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
dreek96max wrote:whatsup s13crazy do you mind doin a write up on the head rebuild...I tried to add you as a friend but dont see how
This thread is from 2 years ago... I doubt he'll even look at this thread
Try this, though: http://www.nicoclub.com/FSM/240sx
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
pic not working, but my guess is tension stopped working correctly and you made spaghetti
dreek96max
93 240 SR20DET
Thanks....can anyone tell me how to add friends and send pm's on here?
