low compression on cylinder no. 2!
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
hey guys....i was thinking about going ka-t using small t25 setup with smic.
but before i did so..i wanted to do compression test.
here are the results.
Cylinder No. 1 : 180 PSI
Cylinder No. 2 : 130 PSI
Cylinder No. 3 : 180 PSI
Cylinder No. 4 : 180 PSI
so the results were not expected..i was getting 180 on 3 cylinders but one was 130psi.
then i droped about 3 droplets of engine oil and retested it but again it was at 130 psi. So im a bit confused why i have low compression in just one cylinder. so i don't know if its the piston rings, seals? etc
overall the ka runs strong..no strange noises or any issues.
any ideas? thankss
also EGR is disabled/deleted
Razi
Car: Moo
If it's still 130 psi after you dropped some oil in the cylinder, it's probably your valve seals.
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
yes to reconfirm. that would suggest either a cracked head (doubtful) or one or more of the valves arent properlly seating
kouki munster
Car: 97 base 240
3 drops of oil isn't going to do anything but get the top of the piston wet, fill the cap of the oil bottle and dump it in the cylinder with low compression, then repeat the test.
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
^ o really? ok i c... i will try doing that tomorow and c if that increases the compression.
thanks
Gabes13
Car: rb20det s13
Probably a bent valve.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
kouki munster wrote:3 drops of oil isn't going to do anything but get the top of the piston wet, fill the cap of the oil bottle and dump it in the cylinder with low compression, then repeat the test.
This. If not could be head gasket, valve seal, or valve stem seals...... Any blow by?
martins_240sx
i can see the headgasket but can you explain to me how a valve stem seal would cause low numbers? I only ask because the valve should be closed creating a seal at the valve seat. and blow by is usaully caused by piston rings crapping out from my understanding. Im honestly running this through my head and would love to hear your insight
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
The back of the valves can wear down, or carbon can build on them which can cause them not to always seal. With good maintenance it's usually not an issue. Chances are it's rings.
martins_240sx
ok i see now. when i was running it through my head i was imagining clean parts. which adds to my could be list
could be the valve guides worn allowing the valve to wiggle and not seat.
