TheOne »
https://forums.nicoclub.com/theone-u18820.html
Sun Aug 14, 2005 12:24 pm
if you did do the compression test the right way, then those are really low numbers and it most likely has blown piston rings or bad valve stem seals.(since you say oil), if the oil you found on cylinder 2 came from bad gasket inside the valve cover, then there would only be oil on the plugs but not inside the piston.
