low compression. Fix???
Psychobob_007
Car: 1992 Nissan Sentra SE-R SR20DE motor with 5 speed manual trany
i was wondering if anyone had any experience with the oil/sealer that is designed to seal your worn piston rings. i just recently did a compression test on my cylinders and came up with about 135 psi across the board. that's about 15 psi under min, and about 40 psi under normal. any help would be greatly apreciated. really don't want, nor have the time, to replace the rings. the engine is a 92 SR20DE with about 172,000 miles. thanks again.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Nothing much you can do about it at this point. Just keep on driving until you can afford to replace the motor. You can get the DE for about 400 dollars.
Psychobob_007
hmmm, where do you think is the best place to get a good used complete motor, i have been thinking of doing an SR20DE build up after i am finished with my other project. thanks for the input.
RED_DET
Vendor
2011 Infiniti G37x
For a straight swap from de to de, I would go with soko motors. If you want a det, then tigerjapanese.com can't be touched on prices.
