rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Fri Jan 28, 2005 6:05 am
Don't forget the proper maintenance! Fluch all fluids and make for damn sure that the motor is 100%. Change sensors that need replacing (O2, MAF, etc) and get a compression test. Then yes, I/E is a good place to start. Mabye look for an SR turbo. Mgmt is nice, but I am running stock tune with my SR T25G and full 3". Boost creeps to 11psi on cold days and hard runs, but the car seems to love it. Also: DO NOT FORGET GAGES> Boost, water temp, and EGT are a good place to start. I have autometer Pro-Comp Ultra-lites on the way (brushed aluminum face and bezel). Easiest way to not break something is to know what is happening to your motor at all times. Also a turbo timer is cheap and can greatly increase the life of that little turbo.
Also, get a BOV and recurricluate it. Turbos hate pressure surge and being a thrust bearing turbo, it won't live long over 7psi w/o a way to vent the extra boost.
