Low boost issues
baz88
Car: 180sx
I have a 1997 180sx typex and lately it has been struggling. I had it dyno tuned and it showed that it was running very lean at 87kw and only 4psi boost. The car has decent mods, including a t28 turbo, hks injectors, hks front mount cooler, 3.5 inch exhaust on an SR20 engine. Anybody know why it could be running such low boost?
okidrift88
Car: 1995 240sx se with sr20det apexi headers apexi airflow converter, g-reddy front mount, blitz blow off valve, aftermarket radiator, electric cooling fans
staright pipe exhaust, 2 ways lsd
check for exhaust leaks, make sure all your piping is tight, and make sure all your boost lines are hooked up right if that dosnt help mabie u have a bad boost controller if u have one or ur turbo is bout to take a s*** on you
