sstroudwku »
https://forums.nicoclub.com/sstroudwku-u211425.html
Sat Jun 29, 2013 9:43 pm
check for voltage at the plugs, if you have source then check the ground side. If these test good you have bad bulbs. I'm having a hard time actually understanding what you're saying other than your low beams are not functioning properly. Your first sentence is very confusing, tuning your low beam bulbs? Do you mean HID?
