low beams dont work, high beams do though? wt*?
miracleboi123
Car: 93 s13 coupe
idk whether its a wiring issue/bulb dies out or w.e
but the other day i had my mom and brother check if my low beams turned on and they werent at all, high beams work well though, has anyone ran into this problem?
i was wondering if changing my headlights w/ sylvania h6054's will help give me your feedback thanks!
ocalas240
Car: 1992 Nissan 240sx
hey man, i ran into this same problem a few weeks back. i put in two new lights and everything was perfect. hope that fixes ur problem!
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
well, duh..
ZX88
Car: s13
its the combination switch. clean it or replace it. or blown fuse for the low beams thats what it sounds like.
miracleboi123
Car: 93 s13 coupe
where is the combination switch? which fuse do i pull out? do you have a diagram?
dickie
Car: Killer Turtle
CSLAVE
Car: 1990 Toyota Celica STX
Its most likely the bulbs man. I had the same prob. A new bulb from autozone and it work fine.
If that don't work then i would clean ur combo switch.
ZX88
Car: s13
i would say its the fuse what are the chances that both low beams just happen to die at the same time. the fuse box is in the engine bay. look at the fsm for exact location/
