Low-beams dont work....High-beams do...any suggestions?
KwayKer
Car: 1991 Nissan 240SX Coupe
I posted this on the nissan mechanic forum, but have yet to get a response...so maybe here I can get an answer. Sorry for double-posting, but I have to work tomorrow, and need my headlights...
The other day I realized in the evening that my headlights werent on, but they should have been. Anyway, the high-beams work, and the low beams dont. I took out the headlights and they seem fine, no rattling when I shake them, so I doubt that both filaments would have blown at the same time. I also checked the fuse box, but no fuses were blown that I could tell. Which fuse should I be checking for exactly? I know they are labeled but sometimes its confusing. Also, when I turn the knob that turns my headlights on, there is a clicking noise coming from somewhere near the fuse box in the engine. Again, my car is a 1991 240SX w/ the pop-up headlights. Everything else works totally fine, I just cant figure out whats up with the low-beams. Any help, comments, or suggestions would be most appreciated. Thanks in advance!
Matt
lbrowne
Replace you sealed beam lights. Not expensive and it should fix you problem. I've seen it many times on many different vehicle with sealed beam headlights, the low beam goes and only the highs work.
hope this helps,
lbrowne
daniel240
Car: cars/motocross
yea i had that prob. on another vehicle and that fixed it.
KwayKer
I'll go pick up some new headlights tomorrow...these are less than a year old though. Also, what are the odds that the low beams would stop working on both @ the same time? Thanks for the advice!
Matt
daniel240
Car: cars/motocross
i think our headlights are hooked together or somthing like that. so if one goes out the other goes also. this is what the guy told me that installed my alarm
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
That clicking you hear is the relay switch, so if you hear it then it IS getting juice (in theory). It is possible that both of your low beams went at the same time.... but more likely one went out and you just didn't notice it until the other went too. I mean... how often do we check our lights.. usually not until we can't see anything because they are BOTH out!:D
Replace them and hopefully that will solve the problem. If not... get back to us!
driftaholic
Car: '91 Nissan RM S13
i had ONE of my lowbeams go out but not the other. both highbeams still worked. i just replaced both units and everything works fine now
KwayKer
New headlights fixed the prob. Give yourselves a pat on the back...thanks alot guys!
Matt
