low beams don't come on
skirodeo7
Car: 2007 Nissan Frontier, 1991 Nissan 240sx
my low beams are screwed. It's an H4 conversion. The plug gets 12v when the switch turns on, but the instant it goes to ground, the power drops to nothing. (.05v to be exact) it's so weird. I checked the ground. no dice. Checked the other headlight, same story. Any ideas? I was thinking either the turn signal/multi switch, or a relay. Anyone?
masterdisaster
Car: 1991 JDM 180SX
rarely the relays..
the first thing i always do with skyline or 180sx is clean and sand the contacts works 95% of times
skirodeo7
turns out the main switch was bad. swapped it out with the turn signal/headlight assembly from another 240 and she works like magic. Now just need to order one. Rock on!
masterdisaster
Car: 1991 JDM 180SX
skirodeo7 wrote:turns out the main switch was bad. swapped it out with the turn signal/headlight assembly from another 240 and she works like magic. Now just need to order one. Rock on!
just do as i mentioned above..and save some $
