Low Beams 2014 Maxima
Jenn413
Car: 2014 Nissan Maxima
2003 Nissan Maxima
Both headlights stopped working at the same time. Bulbs have been changed. Fuses are good. Ground is good. When low beams are turned on the drivers side flashes/blinks 3 times, every time. What else do I check? Mildly mechanically inclined. :confused: :confused: :confused:
Thanks so much!!
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Things you checked:
Bulbs, Fuses, Ground
Things presumably not checked:
Relays
On/Off Switch
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Jenn413 wrote:
Wed Apr 03, 2019 8:28 pm
Thanks so much!!
The headlights are controlled by the BCM, body control module. From what you described it sounds to me that the BCM could be faulty. Particularly the fact that the low beams are flashing in the way you describe.
There is an auto active test that you can try that might help you diagnose the problem, the procedure is described in the Service Manual, starting on page PCS-11
http://www.nicoclub.com/FSM/Maxima/2014 ... ma/PCS.pdf
One thing that you might also try is disconnecting the battery for about 30 minutes, might not do anything but its worth a try.
Jenn413
2003 Nissan Maxima
Thank you so very much for your help!!!!!! I have run the diagnosis, that's when the low beam on the driver's side began flashing 3 times when it is turned on. What else will that tell me? Where is the BCM located?
