sicwitit wrote:It depends if you are able to retrofit the projecter with the motor housing. My low beam Q45 projector retrofit on my IS300 does infact retain the factory auto leveler, so I don't see why it can't be done on your headlights...anything is possible.
Good info, I just wonder if the motor is strong enough to move a projector when its only designed to move a bulb. I'll have to wait until I bake the lights open to look at it. I have a Feeling I'll have to abandon the height adjustment feature tho. it will be a while before I get started I need lots of time to plan and get needed parts.
Anyone know about the hi beam projectors in the qx4 lights? I hate how the light is yellow Id like to get a 4300k d2s bulb in there but I dont know if it will fit. I did the mod to keep the fogs on with the hi beams and my plan is to retrofit tsx projectors in the lows and some projectors in the fogs and go all 4300k for maximum light output.
