Low battery charge
Sheon
Car: !991 Infiniti Q45
I just had the alt and battery replaced and it still says low battery charge and the antilock light and brake lights will not turn off
what could be the problem with my car?
LoxMurda
Car: 93 Infiniti Q45 212k R.I.P.
94 Infiniti Q45 180k and climbing
is this a brand new alternator..was it tested before going in? does the car died after 10 Mins or less?
goody90q45
Car: 1992 Infiniti Q45 (sold)
Those are the 3 lights that come on in the instrument cluster when the alternator is going bad. Check your battery voltage (12v) and the charging voltage (14v+).
Sheon
Yes it was a new alt
When I test it shows 12v off and 14v when the car is on at idle
thanks
with the heater on full blast and the headlights and my system up loud it will drop to 12v at idle but go back up if I increase the rpm
Modified by Sheon at 5:36 PM 3/30/2010
LoxMurda
its the altenator man. I had same issue. If you take the the altenator out of the car and test it @ autozone or something you will find out it is bad. I had mine tested twice in the car and they said it was fine...when I removed it and had them test it..it was bad. It was only 4 months old but I had a lifetime warrantee. Do yourself a favor take it out and test it or get stuck in traffic with people flipping you off, and hot chicks laughing and pointing @ you.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
For some the alternator on a VH45DE is hard enough to remove to replace it. Who know if its not something else and he went through all that trouble for nothing.
Read this at very least: http://www.aa1car.com/library/charging_checks.htm
LoxMurda
altenator has to work in order to keep the batt. charged. Altenator no workee battery no chargee.
