Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Wed Jun 24, 2009 2:17 pm
Quote »Turned it on today and say the message "Low Battery Charge" and later when I left to go somewhere I turned the car on and it said "OK." Now I'm confused why it comes up sometimes.[/quote]It could simply mean that you're not driving the car enough to keep the battery charged. Short trips don't always give the charging system enough time to replace all the power demanded by engine cranking. Also, turning on other electrical accessories (i.e., stereo system, headlamps, A/C, etc.) will consume some of the alternator power that would otherwise be used to recharge the battery, further lengthening the amount of drive-time required to recharge it.
One other suggestion would be to make sure that your battery terminal connections are super-clean and tight - Marginal connections can also lengthen the amount of drive-time required to recharge the battery (or may prevent it from charging at all).
