ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Thu Aug 23, 2007 4:16 pm
Ford 351W with Pro Comp (chinese) aluminum heads. If you look locally, like on Craigslist, you can get a decent 351W for $150 or so. New bearings, rings, pistons, timing chain and the short block is done. Add intake and carb with those cheap alum heads and you can build it for under $2000 and have 500hp and almost as much torque. Add whatever manual trans you want or C4 auto or 4R70W auto if you want overdrive and computer adjustable shifts. That's what I'd do.
