stentoria_s13 wrote:one of the ball bearings in the pulley is probably blown out. i had that problem on my a/c pulley so i took the pulley off. problem solved
don't listen to this guy. f***in idiot, there is no ball bearings in the crank pulley. Why would you even say that? The pulley rotates with the crank and the crank rotates on the crank bearings.
I would try the main seal first. When my main seal was bad it was leaking oil bad but it would also squeal for a second when I let the clutch out to accelerate.
Since its a new rebuild, I really hope its nothing too serious. Noise coming from the crank area is never good.
