t.mcginley.jr »
https://forums.nicoclub.com/t-mcginley-jr-u204971.html
Sat Jan 25, 2014 6:54 am
If its pretty rapid and sounds like its coming from the top of the engine/heads then its probably lifter tick. We have hydraulic lifters which are supposed to fill with oil to cushion the valve movement, but sometimes they get stuck and just bottom out, making that ticking noise. If the engine has high miles then it could be an actual collapsed lifter. If its under like 150k, then it probably just has alot of oil varnish built up on it. Drain the oil and refill with new oil and 1 quart of ATF. Run it for a few hundred miles and change it again. After a few times it should clear up. Change the filter each time too.
