msvara wrote:The squealing may not be the belts. In my case my belts are about 6 months old and the squealing is not the typical belt squealing more a higher pitched squeal. Sounds more like a bad bearing.
msvara, if it was a bad bearing, wouldn't it be making that noise all the time? Its only for a few seconds once the engine starts for the first time in the day. The noise also sounds like it was coming from the radiator area and a not near the belts. I actually had a small chirping sound coming from my belts and sprayed some belt lube a few weeks back and took care of that issue.
