Loud Squeal From Radio
cr506
Car: 1994 Q45
Hi, I bought a 94 Q a little while ago. The radio worked when I bought it (although the speakers were obviously blown) and now all I get is a very loud high pitched squeal from the speakers. It can't be turned down. I have to turn the radio off. Any similar problems encountered?
slybydesignq45t
Car: City Bus
It sounds like a worn out wire or crossed wire. I am no expert but some one may have tried to fix something, hence the blown speaker and crossed wires some how.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Yes. Each speaker has its own amplifier behind/under it. Its common for these amps to go bad after 10 years.
The best option would be to replace it from another 94 Q and from the same side as they have a specific equalization.
But I went ahead and replaced mine from other cars such as Maxima/J30/Corvette/Camaro... actually experimented different combos of amps to find which sound I liked from each speaker.
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
zer...+pump
Seems like there was a factory recall on some due to fire????
That squeal is probably the amp.
You can try this zerothread?id=233344 but it is a bit tedious.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Also
http://www.carstereohelp.com
The 1994 Bose system is not subject to factory recall.
Discard the system and replace with aftermarket equipment. There are very few cars that I believe have better sound systems than most reasonably aftermarket options: Nakamichi Lexus LS400, Bose 4.0 Cadillac Seville STS, and a handful of others. The Q's system is nice, but not spectacular.
