Loud spooling noise
MR.Ka
Car: 1991 240sx SE
every time that i take my car past 3k rpm's it whistle's loud.as if it was spooling.what can it be besides the exhaust.
benemorius
Car: s13, s13, eg, e36
You might want to check under your hood for something called snail syndrome. You shouldn't complain too much as it really isn't a bad thing at all.
Moto Man
Car: 93 240SX
It could be the clutch for your radiator fan. When mine went bad, it sounded like I had a jet engine when over 3000 rpm.
oki_bum
Car: SR Powered 1990 240SX
loud spooling huh? Sounds like a turbo to me. But if it aint a turbo thats spooling, you might want to check the bearings on your pulleys. Mine made a spooling sound on my sohc before it gave out.
MR.Ka
Car: 1991 240sx SE
yeah its sounds like a turbo.....but i never hear the BOV
mad-circle
Car: 240sx coupe 1991
i Have the same problem on my ka but when i floor it there is less power and its spooling , then if i realease it a little it has more power . ..? (scuse my english )
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i looked for this exact same problem for the past two years.
its not the fan, because i dont have one.
its not the intake manifold, or any of the intake parts, because ive swapped everything.
i've tightened and loosened pullies with no avail, and i dont even have A/C. Its not the alternator, thats different too.
Its not a vac leak, because i only use a brake booster and FPR vac lines now. the problem has been around since everything was connected.
its not the clutch or transmission, as that all new or swapped.
for all i know it could be some crazy differential whine...
ive changed or swapped everything, and i cant find the problem, even the head has a valvejob. the only reason i cant hear it anymore is because i got an apexi N1 dual knock off exhaust. but i understand your problem, and people behind the car in other cars can hear this fake spool. people ive beat ask about the turbo, its a legitimate s13 problem apparently...
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
I’ve never heard of or had that problem and my KA had 270k miles before I swapped it. The only thing that comes close to what you guys are talking about is an Alternator that is not grounded properly. I have a friend, who owns a Dodge Daytona, and he recently replaced his alternator, but he didn't ground it properly. One day he was driving up to my house and his car sounded like it had a turbo, I could actually hear that noise coming up the street. After checking everything out he discovered it was the alternator ground problem.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
yeah, my other two KA's were fine...
and i know its not a grounding problem, because both grounds are attached and functional.
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
Hey DJ... do you have a sound clip of your ssac duals?
i havent had a chance to get my ka back in the 240 yet and im dying to hear what they sound like.. ive heard the vid of them on the white kouki.. but thought you might have one too or be able to make one
anyways, it was just a thoughtand btw.. we got one hell of a deal on them too... ive looked back just for the hell of it and none are that cheap now
/end threadjack.. to the op, im sorry
Craving4Boost
Car: 91 240sx fastback
my brother's s14 has this exact whistle...at first it was funny but now it's annoying. if anyone can find the answer please post.
K240
Car: 1993 240sx
possible leaking exhaust manifold?
MR.Ka
Car: 1991 240sx SE
Craving4Boost wrote:my brother's s14 has this exact whistle...at first it was funny but now it's annoying. if anyone can find the answer please post.
I thought that **** was cool too..but i agree when you say it gets annoying........
MR.Ka
Car: 1991 240sx SE
im going to record a sound clip and up load it to streetfire.net ASAP
adrianfromthecastle
Car: 1992 Nissan 240sx
i know exactly what your talking about... my ka makes the same noise, but its not a matter of rev, its how hard i step on the pedal. anyone know if its a problem or can lead to one?
MR.Ka wrote:im going to record a sound clip and up load it to streetfire.net ASAP
cool.. most likely its the same as mines
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i didnt make this, but it sounds exactly like this:
http://media.putfile.com/SS-Au...NA-KA
enjoy, and yes its amazing.
SR20Essex
Sounds like a metallic vibration, loose exhaust system hardware. Check to see if anything is rubbing metal on metal, loose bolts, gasketes..etc
MR.Ka
Car: 1991 240sx SE
mine sounds a whole lot louder than that.because im still rocking the stock exhaust...
K240
Car: 1993 240sx
my sisters coupe was making a loud whistling noise also, i researched it, turned out to be the exhaust manifold had a crack in it. Just a thought.
adrianfromthecastle
K240 wrote:my sisters coupe was making a loud whistling noise also, i researched it, turned out to be the exhaust manifold had a crack in it. Just a thought.
really? i'd think if there was some sort of exaust leak somewhere that it would probably be louder than that... hmmm
K240
Car: 1993 240sx
adrians_s13 wrote:really? i'd think if there was some sort of exaust leak somewhere that it would probably be louder than that... hmmm
Im sorry, Im lost, What would be louder than what?
rsmithdrift
Car: 1993 240sx fastback se.
I fixed this exact problem on my old Z.
It was easy, I removed the catalytic converter for a test pipe and viola!! Sounds great and not a hint of engine whine.
Also check your PS pump isn't going bad. Sometimes they whine even when full if they are going out.
Also if a car has been in a wreck the shape of where the motor mounts are can be slightly distorted, causing a major air rushing sound, doesn't sound much like a spool though, sounds more like a jet engine, same sound occours when your fan clutch goes bad and locks up, or if you get one from autozone. haha.
I'd check that cat, if it's the OEM one still, that's likely your problem, air flow tends to get distorted in there after a hundred thousand miles of carbon buildup.
xckid
Car: 2004 Chevy Blazer ZR2
i took out the y pipe and the intake resonater now my ka when i give it more gas to pass around 3k it gets like a deep rumble lol i like it haha now i just need an exhaust
Lost_In_Translation
Car: 1991 Nissan 240sx, stock with many problems.
Yeah mine also does that weird turbo sound...and people actually ask me if my car is turbo!!! i don't complain that much about the sound. Just hope it ain't nothing bad
adrianfromthecastle
well i have the "spooling" sounds as well... i figured if there was a crack anywhere in the exhaust.. it would be pretty loud, theoretically speaking.. naw mean?
benemorius
For the record, tiny exhaust leaks can be very quiet - even right on the exhaust manifold. Some are so quiet that they are but a whisper.
adrianfromthecastle
benemorius wrote:For the record, tiny exhaust leaks can be very quiet - even right on the exhaust manifold. Some are so quiet that they are but a whisper.
hmm... i did not know that. any malevolent affects down the line?
benemorius
I reckon you might compare it to bird poo on your hood. One day you notice it, wonder how long it's been there, then a week later you don't even give a **** anymore.
STLu13
My altima has a whisting noise, but it sounds like more of a supercharger whine and i figured out that it was coming from my belt (can't remember what brand) which has v ribs in it that come to a point like a tire tread.
BarnDog296
Car: '93 Nissan 240SX SE Fastback KA24DE DOHC
Hey man, i had the EXACT problem on my NA KA
Its an exhaust leak somewhere.
I used to think it was fun to pull on ppl then rev up so they could hear it "spool" its funny as hell. But I got it fixed when I had my 3" piping put on.
When I was getting mine fixed, there was a kid there that LIKED his!?!?!? he cut a small hole in his exhaust to MAKE it make that sound.... god i swear, rice....
