haha my dam phones auto correction but alright i remove the belts and clean them and see if thats the problem. thanks btwbartZ32tt wrote:Sequel (noun): 1.A published, broadcast, or recorded work that continues the story or develops the theme of an earlier one.
2.Something that takes place after or as a result of an earlier event.
Oh..SQUEAL...I get it now.
Simple - check for loose belts. if tight, remove and clean belts and pulleys. reinstall/tighten to correct deflection.
ya its not the belt i think it might be the ac compressor idler pulley since it maakes the noise when the ac gets turned ont.mcginley.jr wrote:If it isn't the belts being too loose it could also be the idler pulleys themselves, the bearings go bad after a while
Thanks. Which Z is yours? im prety sure ive seen all Z's here in temecula. Right now now its not looking too good, i havent washed it in a month, i did some small touch up on rock chips recently and im waiting a couple of weeks for paint to fully cure.localz32 wrote:H1tman I've seen your z a couple times here in temecula its really clean
