sileightysomeday »
https://forums.nicoclub.com/sileightysomeday-u27251.html
Tue Jun 05, 2007 9:01 am
Ok, so I was driving my car from Jacksonville, FL to Orlando. which is roughly 160 miles. and on my way home i started to hear this rattling, at first it wasn't that loud and i thought it was my airbox hittle the frame, then i got home and noticed it was coming from under the valve cover. So I opened up the valve cover and looked at the head, everything seems fine. I did a search and checked the right chain guide and it looked fine. Ideally I would like to start the car with the valve cover off to see where its' coming from, but obviously I can't do that cuz I don't want to be covered in oil. anyway, so at idle it sounds like there are marbles or metal pieces rattling around in the head, then i rev it up and it sounds like a chainsaw with a dull chain grinding against metal and the rattling stops. I keep thinking it is the chain guide but I'd like a second opinion. there was a great article that i found here that said the guy drove like 50k miles with it like this and was fine. So what do you all think? the car is a '90 SOHC stock KA. is it safe to drive ? or should I avoid it? thanks in advance.
