Loud Metal Sound When I Back Up
sunryze88
Every morning when i back out of my carport i have to make a tight turn to get out because the street is so narrow.....when i turn my wheel all the way i hear what sounds like metal rubbing together...its really hard to explain but it is a loud sound....i have no clue what it is and it only happens when i reverse while turning...any clue anybody?
MaximA32
Aftermarket wheels/tires?
beavis327
Depending on what Nissan you have possible steering stops missing or cracked. Makes a creeking noise on the up-down movement.
Fix is to replace plastic cap on the lower part of spindle near ball joint on most cars or truck. then lube up with white lithium or bearing grease to smooth out rubbing. should cost no more than $1.00 to $5.00 a cap depending on car or truck
