carkook wrote:I thought the same exact thing with my ka24e, turns out two of the exhaust manifold studs are gone.. and its leaks from the manny everytime the third piston fires. Sounds exactly like ticking, rpms go up it ticks faster. I would check that out.
yeah,its not that.....i wish haricebike wrote:
didn't you check out his reply?
i've got that similar problem but didn't get around to fixing the leak yet...
moulton712 wrote:also what weight of oil do you use? if it's like 5w 20 use a heavier oil.
also sometimes when people are referring to the timing chain noise, they mean timing chain guide. the guides wear out or get warped of even break. it's a 5 hour mod to remove the guide.. the guide is not needed.
neither. People are not paying attention that you have a sohc. Try a little lucas in your oil next time you change it. It may be a good idea to check your oil pressure to assure good flow. Idk too much on how you adjust the rockers on the sohc or if you even can. Did you do the timing or someone else. Unless you did it, just because the chain was done doesn't mean the tensioners or guides were replaced.driftiteasy0113 wrote:which guides?there is only 2 on the sides..do i remove both?
either your oil level is a tad low, or your hydraulic lifters are not getting enough oil...slyedog240sx wrote:... People are not paying attention that you have a sohc. Try a little lucas in your oil next time you change it. It may be a good idea to check your oil pressure to assure good flow.
ya a local shop did it,so ya i wasnt actually thereslyedog240sx wrote:neither. People are not paying attention that you have a sohc. Try a little lucas in your oil next time you change it. It may be a good idea to check your oil pressure to assure good flow. Idk too much on how you adjust the rockers on the sohc or if you even can. Did you do the timing or someone else. Unless you did it, just because the chain was done doesn't mean the tensioners or guides were replaced.
i would have a chat with them to be sure.driftiteasy0113 wrote:ya a local shop did it,so ya i wasnt actually there
