szh »
https://forums.nicoclub.com/szh-u149.html
Sun Nov 30, 2008 10:17 am
Using 87 octane in a car designed for 91 is going to cause problems in the long run - including with the occasional bad gas that does not even reach 87! I don't understand your reason for doing this. If "cost", then this is false economy, since the "added" cost, for most driving, is less than $15 a month (maybe even lower than that ... now that gas prices are down a lot). The engine is designed for premium ... treat it that way!
Yes, the engine burns oil when not broken in properly, but this is not a particularly unusual thing in high-performance cars nowadays. Many cars exhibit this, and the M45 engine is, unfortunately, prone to it as well.
If you use less than 1/2 quart every 1750 miles (measured halfway between changes), then this is not a big deal.
Use BG-44K as a preventative measure just before every oil and filter change, and the engine will be a lot happier all the time. Lots of WOTs help too (and are fun regardless ).
Running the engine for a brief while and not allowing it to get up to temperature is a sure method to create problems, I agree. So, like the Doctor says when you ask him "it hurts when I hit my head": "Stop doing it!"
Z
