evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 28, 2007 6:36 pm
the Z31's (84-89) are all "single cams" there is actually 1 in each head, the Z32 (90-96) are all "twin cam" 2 cams in each head
as for 13's, remove as much dead weight as possible, I suggest pulling the bumper covers to remove the actual bumpers and put the covers back, not ideal for street as if you get hit you're not protected, but for the drag strip I say lighter is better, also the stock seats are heavey get the passanger out and at the very least, add a front mount I/C and turn up the boost you shoud be in the high 13's, might be wise to up the fuel pressure a coupla lbs and retard the timing an extra coupla degrees for saftey, I also recomend race gas, and the obligitory intake and exhaust should help get you securely into the 13's, ans stock wheels and tires might well be less weight than aftermarkets, decent drag radial swill help get you out of the hole
