loud Intake Sucking = Vacuum Leak?
NateDogg
Hi,
I have a '91 240sx with a K&N cone filter. I'm having trouble diagnosing a problem with a hesitation and I read in a post that if your intake (cone filter?) makes a loud sucking noise, you may have a vacuum leak. Is this correct? By the way I get 20inHg vacuum at idle and it's pretty solid.
s13sr20chris
nope. a vac leak is a leak somewhere after the maf. all intakes make sucking noises. even the stock one if you unlatch the air filter.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
My K&N makes the same noise. It's perfectly normal.
