Loud Engine Fan
YNOS_ES14
Model=96 S14Engine=KA24DE no modsProblem=Fan is very loud at any RPM. It squeeks at 4k plus. Small loss of power.
D Money
Car: driving illegaly
get rid of that fan and get the a/c fan to run all the time or with a switch
YNOS_ES14
Not in my budget right now. Need to find a fix :)
MikeMurphy
Car: Guess
Electric fans are cheap as hell. But you gotta hitup the junkyard. Wiring is cheap too. Probably will cost you in total 40-50 smackers. If you have A/C then you have a fan. Just gotta rewire. I just took off my clutch fan.
Jonny 290
How does "get rid of the clutch fan" cost money?
Unbolt the damn thing, rewire the A/C fan relay to work off a +12 switched line, boom. done.
it's not hard. and if you'd be interested, i could post more detailed instructions tomorrow. :)
you've got a couple of months until you start getting serious heat out your way. your cooling system will be fine until such a time. mine lasted a season of hard N/A action with just the a/c fan, though I do have my A/C condenser removed.
D Money
i took my fan out 3 months ago and it so cold out here i didn't have to connect anyfan
Kavkazia
I really want to get rid of my mechanical fan, because I notice some cracks on it!
I do have a/c with electric fan but I was wondering if you could wire it somewhere to make it only spin when it gets hot?
Or just make it run all time? Or with manual switch?
YNOS_ES14
Jonny 290 wrote:How does "get rid of the clutch fan" cost money?
Thanks. I am interseted. :D I look forward to your post.
Jonny 290
Cool, i'll snap a pic or two of the relay and all that rot this weekend, and write up some instructions. It's cold and I dun wanna go outside :D
Nismo_Freak
Car: 89 Nissan 240SX
Sounds like a loose belt to me.
Secret Agent
It could be your fan clutch. You can check it by seeing how freely the fan turns (check it with the engine off). If it is stiff, you've found the problem.
When mine went bad, it sounded like I had a jet engine. That was cool, but sometimes it squealed which was very annoying.
I replaced it with a new Nissan clutch, which was surprisingly expensive. :rolleyes
goldenchild
Car: 90 Nissan 240SX KA24E-t go bye bye, gotta another in the works
I just installed my 2 12 inch fans with thermostat, works very good
s14/se
Car: whatever seems fun at the time
http://240sx.org/links/install...l.htmthis link should help you it's under the install section
deCksy
s14/se wrote:http://240sx.org/links/install...l.htmthis link should help you it's under the install section
would this work for a s13? my fan is sqeaking like a mofo
fuzion
Car: Cars.. Web/graphic design.. Yuppp
prolly fan clutch.. is it on all the time?
Altho, with it on it sounds like you've got a monster engine in there.. ITS SEXY :)
hehe.. new fan clutch is around $200 from nissan, $50-$75 from your local auto parts store [non nissan of course]. Make sure your belt isn't too tight or loose..
