Larz »
https://forums.nicoclub.com/larz-u216291.html
Wed Jul 09, 2014 12:30 pm
I drive an 07 M, so we have the same engine. I'm not sure what you mean by "high revs". Are the revs high compared to ... other M's? compared to other brands of cars? or do you suspect they are high compared to what is 'expected' from a V6 24v engine?
All I can tell you is what my M does. At idle, revs are about 700. At 40 mph, revs are about 1,500 ... at 75 mph, revs increase to about 3,000. But that is FL driving - mostly flat smooth roads with no steep inclines, etc. But here's what's interesting: Those figures are with cruise control switched ON. Driving with your foot, the revs will always be higher, because we can't manually maintain speed with the least amount of pedal pressure and fuel - as does the Cruise Control.
Cabin noise: Infiniti has never been known for quiet cabins. Mind you, they are very well built, but little or no sound deadening is included in the process. Most reviews of the M will mention that the cabin is a little more noisy than expected, but not "loud". The M cabin seems more susceptible to noises from tires and road surface depending on the quality and brand of tire you ride on.
Engine noise: When I am stopped at a traffic signal, I don't notice any engine noise or vibration. It seems as if the engine is switched OFF. At motorway speeds above 65 mph, there is noticeable engine / exhaust / wind / road noise but not what I consider to be loud or intrusive. The radio covers it pretty well.
Hope this helps
