Loud Clicking Sound - Air Conditioner/Heater
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
kansas400
Car: Infinity QX56
Hi - I am a new owner of a 2004 Infinity QX56 and I notice that when I turn on the heat or air using the front vents, there is a loud clicking sound of about 10 clicks before it stops.
I'm wondering what the issue is if anyone else has experienced this?
Thanks.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
How much mileage is on your truck?
kansas400
Car: Infinity QX56
71,000 miles.
Thanks.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to the group Sorry about the delayed response.
In my opinion what it sounds like is a motor for one of your Air Conditioner mode doors slowly dying. There is a small reverse polarity drive motor for 3 different modes. If you scroll through the modes by repeatedly pressing the lower middle (? depending on year) and waiting until the airflow changes. If you notice the noise while the mode is changing that would be a big red flag in my book. There are several other thins but from your description that is the first things that I would check.
IFlySXi
Car: 2005 QX56
How hard is it to replace AC mode doors drive motor? And how do I figure out which one it is?
Thanks,
Brian
dnwhoop02
Car: 2010 Titan
I have a 2010 Titan with 25,000 miles on it, and I have the exact same noise. I doubt the motor is already going out, sooo any other ideas?
BradW
Car: 2008 QX56
I just had that fixed on my 2008. It happened to me when you go from defrost to vents. It would also do it after you turn the vehicle off for a few mins. The dealer said its a smail cheap part. I will look on my invoice for what was replaced.
BradW
Car: 2008 QX56
My invoice says replaced Heating Defrost Door Acuator
Part# assy-27743-zp00a
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
DOES IT SORT OF SOUND LIKE A WOODPECKER IN YOUR DASH?
They actually just had recall on those on the '08 and newer. I originally had mine replaced once under warranty, then replaced a second time under the recall with a new version. Nissan also extended the factory warranty on the HVAC blowers.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
The parts for this repair are quite reasonably priced (I'd guess less than $30/ea) labor is a bear on that one though. For the noise on the right side the it requires the dash to come out. The left side one is precariously located between the Bose amp and the BCM behind several razor sharp segments of structural aluminum bars.
IMO this is one to save for the pros.
Timmbo
Precisely what my tech told me as well, complete PITA!
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
One of the guys I work with ended up going to the hospital for a severe cut from one of those recall motors. That was the worst seven tenths of an hour he's ever made.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
