Loud Clatter from Valve Train - Broken QX4
drj9000
Car: 01 QX4
My 01 QX4 started making a loud clatter from the valve train and started missing with the check engine light flashing. I was going up a long grade in the mountains when it happened. It was still running but with a loud clatter that increased with rpm. Oil level was good and engine temp was OK. 240 thousand kilometers on he clock.
I had i towed to a shop in he nearest town, but have no idea what it could be other than cam or valve related.
Camelfilter
Car: 1999.5 Pathfinder SE
2009 Titan Pro 4X Crew Cab
?power valve screw(s) fell out?
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
If the SES light was on, what were the codes?
Automatic or stick (sticks don't have a power valve).
Chuck
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Sounds like a power valve screw assuming you have an auto transmission. These are the power valves under the upper intake manifold:
Take the UIM off (guide here) and make sure all 12 are there. If they are, apply red threadlocker to all of them; if one or more are missing, then that is your most likely cause of the clatter and other potential damage.
If it is truly a power valve screw, this unfortunately makes the third or fourth QX4 with a power valve screw related issue in the past 6 months or so. It's a little odd that all have been QX4s and not Pathfinders.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
think how many hundreds of people that arent on this forum that have this power valve failure happen to them
So glad I openned my manifold up before it happened to me
drj9000
Car: 01 QX4
Fixed.
2 loose spark plugs. Apparently they were not tightened to the proper torque the last time they were replaced. Had all 6 replaced for $400 CDN. (scoped, plus 2 hours labour)
Big relief, I have to say...
Thanks for the input.
Towncivilian
What a simple fix! I'm glad you haven't suffered any lasting damage. You may want to look into having threadlocker applied to the power valve screws preemptively.
CanuckQx4
A loose spark plug doesnt create a loud clatter that resembles the valvetrain as you said tho...
