Hey all.. FIrst of all I searched for a turbo stick but I couldn't find one so I'm asking you. I have a 97 Kouki with about 140k miles on it. The engine runs strong on an OEM clutch. Here she is:
I am saving up for a blacktop but untill I can save up I want to get a T25 Turbo Kit. I have a lot of questions about Turbo Setups, Firstly My engine runs strong, Do you think I need to rebuild my engine for a T25 turbo running low boost? If so, What is commonly replaced to prep for Boost? I heard that I should have: an oil cooler, fuel pump (255lp?), Fuel Injectors (What cc?), Boost controller (How much PSI would my turbo run at without the Boost controller??), upgraded ECU. Please let me know Which one of These things I ABSOLUTELY NEED and anything I didn't mention. What will happen if I don't have them. Also is a T25/T28 Turbo better? Please Chime in with your two cents. Thank you All !!
