Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Tue Jun 17, 2003 9:15 am
You're running too rich. Culprits are many. The usual suspects are O2 sensor, coolant temp sensor, MAFS, fuel injector leaks. Check your ECU to see if it is throwing any codes. There's a detailed section in this forum on how to access the ECU and activate the self-diagnostic - search. Also look at the engine while it's running, see if you smell gas leaking directly from the injectors as it idles.
