evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Sep 09, 2010 10:10 am
wow, lets see
a velocity stack is a sort of air horn that allows velocity to draw in more air than it would otherwise, but has no practical or useful application in the z32
hardpipes, just depends, I opted for the silicoln hoses as they are a lto easier to get on an off
a manual boost controller is a bleed off valve you adjust it by trial and error, an electronic boost controoler is electronic and precise but a lot more money
depends on what you want, most people just get the cat back exhaust, the other exhaust mods offer little for the money, on the case fo a turbo car the downpipes can sive some weight as well as pita factor
, but if you have emissions testing you need to keep all the cats
not sure what tuning z1 se;lls but zeumlator, romulator, nistune etc will get you results on google, but for a beginner I'd skip it, the romulators are for tuning every possible bit in conjunction with a dyno wideband and knock detection, not for beginners
no, remote adjustable coil overs only adjust shock valving, not ride height not camber just dampening, not worth the money imho, and won't do what you think it does
bigger wheels are not uncommon, they gernally add weight and have no real benefit, the wider rears might help a bit with straight line traction, and the sidewall si an aspect ratio, that number means nothing without the width, and having 19's ont he frotn will make it feel harder and you are more likley to bend a wheel on a pot hole or get tht twitchy feel in a rut in the road
