lots of questions i have not answered by the SEARCH button....
turboweege
ok, im planning on turboing the 240 this summer and no one i know of has tried to use as many dsm parts as i plan, but since i have a garage full of dsm parts im thinkin i can do it for next to nothing, by the way i have a ka24e. i plan on 7 psi intercooled with a dsm t25 turbo and using a safc for fuel.1. im planning on using either 390 or 450cc dsm injectors. which would be bettter and also are nissans high or low impedence?2. since id be using a t25 the turbo will basically have to go upside down to fit like everyone has theres, can i put it down or is up the only way to go to drain the oil properlly?3.would a dsm fuel pump work in the 240?4. where can i find a wiring diagram to wire in my safc to the stock ecu?5. what can i do to modify the wastegate to open at say 5psi intead of like 12? i saw one post about it to a denver site but the link is now dead along with the info.thanxluigi
cow
Car: beep beep
Well first I can definitely tell you, do not waste your time with a t25. That turbo is too small for a 4g so it will be WAY too small for a no-top-end 240. Get at least a t3/t4. As far as oil draining I'm not sure what you are talking about. Maybe a pic would help?
I don't know about the fuel pump. I don't see why not, as long as you wire it correctly.
Wiring diagram.. search around 240sx.org, i think they have a few. If not you can always buy a service manual for your 240 (good idea anyway).
As for the wastegate, get a softer spring.
S13Ka24e
Car: Tunning, reading, learning
1. Well 240sx is high impedence. Are the injectos Top-feed (i assume this if for you 1990)? They still may not work they have to fit into the intake too. iirc they don't work.
2.I would say a t25 is too small for a 2.4L i wil choke the engine at high rpms.
3. I wouldn't think a fuel pump would work.
4. i don't know.
5. I don't know. I didn't think you could.
I have never of many people using DSM stuff, most people use nissan stuff. z31 turbo, sr or ca injectors, z32 fuel pump, etc.
turboweege
ok, so a t3/t4, ok. well what size t3/t4? and yes the injectors are top fed. i have the rail off my dsm so if they dont fit right in ill modify the rail. and would a 140lph be enough for a 7psi system with 390 or 450cc injectors or should i go to a 190 or 255? thanxluigi
turboweege
also, i have a new stock clutch which im sure is gonna say bye as soon as i start boosting, so can i just get a bigger pressure plate with the stock disk or should i just go with a whole kit?
turboweege
and you guys say a t3/t4 would be better...what size ar should i be looking for an the intake and exhaust sides?luigi
midnight brother
If you don't want to go with an expensive gigantic turbo find out what turbo the 2.4 DSM Hybrid guys are using. I know someone on DSMTALK is using a 20G and having no problems.
turboweege
ok and a 20g is not a gigantic turbo???lol. im probably gonna go with a garret turbo i can get form my friend. it has an A/R.42 turbine and A/R.48 exhaust. think thatll work fine. im sure it will.
KApwr
turboweege wrote:and you guys say a t3/t4 would be better...what size ar should i be looking for an the intake and exhaust sides?luigi
Best T3/T04E would be Cold side=50trim (.60a/r) and Hot side= stageIII (.63a/r). This turbo is proven to respond and perform well on both KA's and SR's. Good luck!!
turboweege
thanx for the help...any help on the other stuff?luigi
syka24et
Car: Turbo cars
as far as wiring diagrams go I would get a factory service manual of ebay I just got one for 30 bucks. Very valuable info. It has the whole car's wiring system laid out.
turboweege
how well would an rhb5 turbo work? is it big enough??
