oversteer180 »
https://forums.nicoclub.com/oversteer180-u26824.html
Mon Dec 26, 2005 9:57 pm
1.When I have the key turned to acc. should the 2 diagnostic lights (red & Green) on the ecu be lit up? 2. Also, I have an hks turbo timer type-0 w/ harness, I know the harness needs to be plugged into the harness underneath the steering column, but what about the other 3 or four wires coming off of it? 3.Also, is there any way I can check my wiring on my Ka24e S13 to s13 ca18det with an auto-to-manual conversion without starting the engine up. I dont have the turbo, and radiator hooked up. Are there signs to show me that i did the wiring right without having to start it up... 4. Also, for some reason my "brake" and "check seatbelt"indicator light is staying on even without the key in or the car being turned on..i didnt know if this had something to do with the wiring, the turbo timer not being fully hooked up, or the lack of me doing something right on the auto to manual conversion.. Sorry this is alot...but please help!!!
