lots of problems
DMiester129
Car: 98 Pathfinder
01 Pathfinder
90 Mazda 929 x2
92 Toyota Cressida
whats up guys I've been a long time lurker cause my 98 was soo damn reliable but I recently acquired an 01 LE with the check engine, abs, and 4wd light on
check engine light is because of p1311 swirl control solenoid I did the diagnostic per the fsm and double checked and cleaned the hoses/manifold and still no dice. I'll order a new one from courtesy
next up is the abs light. I ran the self diagnostic and came up with code 12 which is nothing and code 21 front right wheel sensor. I performed the resistance test and the sensor came up open. I'm going to double check my test on the front left side before I condemn that sensor its a little pricey :ohno:
also i dont know if this is normal but when I turn the key to the on position I can hear the abs pump/motor working
now the 4wd light has me stumped....
when I ran the self diagnostic on that I got 1 long flash and 17 short ones :wtf2:
here are the symtoms
when I start the car it isn't on but after moving about 4-5 feet the light comes on.
the 4wd still works even though the light is on
ganesh21
Car: '12 Honda Pilot
When my ABS light come on, it would also turn on the 4WD light. 4WD would work fine.
Fix the ABS light and the 4WD light will go away. (Not guarantee)
Finkle
Car: 2004 Pathfinder Platinum LE 4x4
my 4wd light has come on too. No other lights. 4x4 still works. I have no clue. What are you using to get the codes?
DMiester129
Car: 98 Pathfinder
01 Pathfinder
90 Mazda 929 x2
92 Toyota Cressida
fsm self diagnosis... you do a bunch of shifting and turning the key and then you count the flashes
DMiester129
Car: 98 Pathfinder
01 Pathfinder
90 Mazda 929 x2
92 Toyota Cressida
DMiester129
Car: 98 Pathfinder
01 Pathfinder
90 Mazda 929 x2
92 Toyota Cressida
ok well I tried pulling out the broken bose 6cd player and that was a big fail :cry: does any one have the wood trim for the center console I need the clock and the radio pieces :facepalm:
also I've been checking out other pathy's and they all seem to have different running boards from me.. I have an 01 LE and I have black nerf bars that say nissan on the step pads
