lots of problems
a 1g terror
Car: 1g dsm 12,9
So. i finaly got my 240sx all back together. try and start it. Have a few problems.
there are NO dash lights on, NO dummy lights on, NO tail light or brake lights. headlights work...but dont flip up.
The motor cranks and is getting gas but no spark."spark plugs coverd with gas"
when i picked up the car the harness looked like this...
I took it out of the car connected and solder every wire back to the way it should be. im 95% sure that every wire is hooked up to the right one.
car has a brandnew trans harness on it becaus ethere was nothing left of the old one.
the car is soposeto have ran good. but the little ricer that owned it befor me had his way with it...
any ideas?
Modified by a 1g terror at 10:32 PM 6/13/2006
Modified by a 1g terror at 5:11 PM 6/14/2006
a 1g terror
Car: 1g dsm 12,9
oh yeah. the car is a 92 240sx 5speed
HKSdrift3r
kinda sounds like my harness was. what was his reason for it being all fubar'd? btw, theres no pic. And if you thought your DSM was full of problems, like mine... well, its just began. but you already know that
a 1g terror
Car: 1g dsm 12,9
should be a pic now... anyway.. i guess it was chopped up for a rb25 swap. not the right way obviously
5upra
Car: S197
get out your DVOM and start checking wires for correct placement and voltage
a 1g terror
Car: 1g dsm 12,9
Im have an idea of why its not sparking, but im pretty lost about the other stuff. sounds like a fuse but i checked them all
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
You are missing some info, is this part 2 to something??? Sounds like you just swapped the engine, maybe.....or bought the car like this.....provide more info on the situation. About the wiring job....man I hate to tell you this, that looks bad. I looks like you are still working on it, but you need to make sure that you have good connections. Butt connectors are not very reliable when it comes to engine signals and conductivity. My suggestion is to check all connections, redo connections with solder and heat shrink. And secure all wiring as neatly as possible.....
a 1g terror
Car: 1g dsm 12,9
amolao wrote:You are missing some info, is this part 2 to something??? Sounds like you just swapped the engine, maybe.....or bought the car like this.....provide more info on the situation. About the wiring job....man I hate to tell you this, that looks bad. I looks like you are still working on it, but you need to make sure that you have good connections. Butt connectors are not very reliable when it comes to engine signals and conductivity. My suggestion is to check all connections, redo connections with solder and heat shrink. And secure all wiring as neatly as possible.....
any ideas?
its all there. i got the car this way. its a 92 with a ka24de
the pic is how i bought the car now the way it is now
a 1g terror
Car: 1g dsm 12,9
a 1g terror
Car: 1g dsm 12,9
YAY it runs, now i need to figer out the lighting problem... any help? i checked the TCU and fuses
ArcherV20
Car: 1995 240SX
I know this might be too obvious, but who knows - did you check the actual bulbs?
a 1g terror
Car: 1g dsm 12,9
UPDATE ok so i got it runing better.. grounded the yellow/red TCU wire same thing... no lights or power anywhere in the car. rev it up to about 5k just to clear it out abit the wipers come to life and everything works fine but the power windows.
