I have parts for sale that I don't need. All of them were to rebuild my Datsun 260z back to stock, but I decided to do something else. While most things listed have a price, I am willing to accept offers because I need them gone asap. They're taking up much needed space in my garage. I would be interested in trading if you have something(s) I may need. I may also have other parts I forgot to include, so don't hesitate to ask anyway. Everything is located in Naples, Florida.
Sorry if this post is a bit long. If I am in violation of a rule I overlooked, I apologize. I am also not a dealer, nor do I run a commercial business. These are all parts that came with the sale of my car that I don't need.
Pictures: https://photos.app.goo.gl/59C1ULfqWX8AL4XN9
Part Name "New/Used" Part Number Price
3-way water hose pipe connector N 14051 E5600 $25
Air Cleaner With hoses U $55
Belt - Goodyear Gatorback N 15346 $25
Belt - Goodyear Gatorback N 17345 $25
Boot Clutch Release Fork - rubber N 200-420 $12
Brake fluid proportioning valve U 0803-8 $50
Brake light switch valve U $15
Break Booster Check valve N D7478-40500 $35
Break Master cylinder OEM N 46010-N4700A $100
Clutch Slave Cylinder Valve N 613400 $15
Complete gasket set N FS84136 $80
Distributor cap and rotor N $20
Flat top carburetor - pair U $400
Fuel filter N 16400-C6400 $20
Gasket seal N $80
Glove box compartment, no door N $40
Hitachi (flattop) Carburetor rebuild kit N 15569 ? $25
Hydraulic clutch master N $115
Ignition key assembly and keys N $120
Manual - 1974 Datsun 260Z Service U $300
Manual - Chilton's Datsun Z & ZX U $10
Manual - Hayne's Datsun 240Z & ZX U $25
NSK rear wheel bearing bearing N 051-3160 64-01144 $31
NSK spark plug wire set w/guides N RC-NE61 $45
PCV valve N 11810-E3001 $9
Radiator drain petcock N 200-682/683 $8
Radiator hose - bottom N 21503-N4200 $20
Radiator hose top N 21501-N3000 $20
Rear Brake hose N 4620189909 $20
Rear Break Drum Hardware Kit N 17185 $10
Rear bumper rubber shield U $100
Rear Hatch Window Weatherstrip N 90305-E4100 $55
Rear view mirror - driver’s side N 96302-N4700 $30
Replacement Heater Hoses N $20
Replacement lightbulbs (10) N $20
rocker arm U 13257-21000 $10
Round top carburetor - pair U $300
Set of brake shoes N $53
Set of calipers N $170
Set of spring clamps U $15
Shifter knob U $30
Steering coupling - rubber N 48073-78500 $30
Thermostat kit N 21200-P7991 $60
Tool compartment doors U 1119-8 $80
Water inlet port N 13049-P0300 $24
Water outlet port N 11060-U0100 $25
Water pump N 28-9011 $25
L26 long block with manual transmission e88 head, p30 block make offer
L24 long block and manual transmission e31 head, p30 block make offer
Front chrome bumper bar Make offer
Rear chrome bumper bar Make offer
Soon, the following will be for sale:
260z front subframe + suspension make offer
260z rear subframe + suspension make offer
