lots of ka24e specs.
brandonDavid
Car: 1992 240sx, 1992 D21
bored at school today, got on AllData, got a decent amount of specs. plan on getting more for the DE tomorrow.(edit) feel free to sticky, when it's done and over with should be worth it
Okay, to start out.
Engine Model: KA24ECylinder Arrangement: 4 InlineDisplacement: 2,389cc / 145.78ciBore x Stroke: 89 x 96mm / 3.50 x 3.78inValve Arrangement: OHCFiring Order: 1-3-4-2Number of Piston Rings: 2-Compression, 1-OilNumber of Main Bearings: 5Compression Ratio: 9.1---------------------------------------------------------------------------------------------------Compresion Pressure Unit: kPa(kg/cm, psi)/rpm
Standard: 1,324(13.5, 192)/300
Minimum: 981(10, 142)/300
Differential limit between cylinders: 98(1.0, 14)/300
Compression Specs:142-192 max. variation is 14
---------------------------------------------------------------------------------------------------Rocker Arm and Rocker Shaft
Rocker arm to shaft clearance: 0.012-0.050mm / 0.0005-0.0020in
Rocker shaft diameter: 21.979-22.000mm / .8653-.8661in
Rocker arm rocker arm shaft hole diameter: 22.012-22.029mm / .8666-.8673in-------------------------------------------------------------------------------------------------Camshaft and Camshaft Bearing
Camheight bottom to top of lobe: 44.839-45.029mm / 1.7653-1.7728in
Valve lift: 10.4mm / 0.409in
Wear limit of cam height: 0.2mm / 0.0047in
Camshaft journal to bearing clearance: 0.045-0.090mm / 0.0018-0.0035in
Inner diameter of camshaft bearing 33.000-33.025mm / 1.2992-1.3002in
Outer diameter of camshaft journal: 32.935-32.955mm / 1.2967-1.2974in
Camshaft run out: 0-0.02mm / 0-0.0008in
Camshaft endplay: 0.07-0.15mm / 0.0028-0.0059in---------------------------------------------------------------------------------------------------
Valve
Valve head diameter: intake: 34.0-34.2mm / 1.339-1.346in exhaust: 40.0-40.2mm / 1.575-1.583in
Valve length: intake: 119.9-120.2mm / 4.720-4.732in exhaust: 120.67-120.97 / 4.7508-4.7626
Valve stem diameter: intake: 6.965-6.980mm / 0.2742-0.2748in exhaust: 7.948-7.960mm / 0.3129-0.3134in
Valve face angle: intake&exhaust are both 45 degrees
Valve head margin: intake: 1.15-1.45mm / 0.0453-0.0571in exhaust: 1.35-1.65mm / 0.0531-0.0650in limit: .5mm / 0.020in
Cylinder head seat recess diameter:
Standard intake: 36.000-36.016mm / 1.4173-1.4179inexhaust: 42.000-42.016mm / 1.6535-1.6542in
Service intake: 36.500-36.516mm / 42.500-42.516inexhaust: 42.500-42.516mm / 1.6732-1.6739in
Valve seat outer diameter:
Standardintake: 36.080-36.096mm / 1.4205-1.4211inexhaust: 42.080-42.096mm / 1.6567-1.6573in
Service intake:36.580-36.596mm / 1.4402-1.4408inexhaust: 42.580-42.596mm / 1.6764-1.6770in
Face angle:
45 degrees, both standard and service.
Contacting width:
Standardintake: 1.6-1.7mm / 0.063-0.067inexhaust: 1.7-2.1mm / 0.067-0.083in
Serviceintake: 1.6-1.7mm / 0.063-0.067inexhaust: 1.7-2.1mm / 0.067-0.083in ---------------------------------------------------------------------------------------------------
That's it for now, i gotta get to work, i'll be back on later with a lot more.
Modified by B-Metts at 3:53 PM 3/3/2009
Modified by B-Metts at 3:54 PM 3/3/2009
brandonDavid
guess no one really cares about the ka-e anymore? i mean, not really receiving any feedback so don't really know if i should keep going with the specs.
w0nderbr3ad
Car: 1990 240sx with ka24de swap
Its not that no body cares about the specs, its that a majority of people wouldn't know what to do with the info and without proper tools its hard to measure these specs. If you had your hands on the DE specs I'd be grateful.
brandonDavid
w0nderbr3ad wrote:Its not that no body cares about the specs, its that a majority of people wouldn't know what to do with the info and without proper tools its hard to measure these specs. If you had your hands on the DE specs I'd be grateful.
yeahh, didn't really think about that. and actually i do. i'll probably throw them on after this weekend. it's gonna be a busy one. driving back home, doing the clutch on my truck, pulling the old de motor out of the 240, bring up the e and blah blah blah. and i don't know how many motors people rebuild on here but you're right. usually just have the machine shop do all them. but like i said, i've got some de specs. not as much as the e, don't know why. still wish i had a scanner.
'89240sx
Car: 1989 240sx s13 1995 Dodge Neon(5-speed swap)
i kno this is an old thread but i appreciate it cuz i just bought my first 240sx and it has the ka-e
Scuba002
Car: 78 Datsun 620, 89 Nissan 240SX
I just purchased my first 240SX a week ago same story....KA24E
chr1su12
Can you get me the DE info?
S133P3R
Car: 1989 S13 240sx
very useful info! thanks for sharing, needed to find valve specs to try to find some good valves for a KA-e build.
THANKS!
soon2Bcool
Car: '93 240sx Hatch
DE specs??? anyone? anywhere?
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
nice
lptimmy
Car: 1990 nissan 240sx hatchback
i just got my 240 and it has the ka24e i appeciate these specs, i am just getting the engine running good til i can afford the sr20. do you happen to know any good sites for stock parts, and know anything and valve adjustent, i got a pretty good ticking.
