kaboost90 »
https://forums.nicoclub.com/kaboost90-u141798.html
Mon Aug 31, 2009 8:06 pm
Test your spark and compression if there both good sounds like you did a bad rebuild and a valve isn't opening or your timing is way off to get to TDC stick your thumb in the #1 cylinder spark plug hole have it air tight as you can have a buddy crank till your thumb releases the pressure in the cylinder thats tdc some times crank pullys arnt 100% accurate or when you removed it could have spinned around good luck hope the rebuild was a success
