Shift__BODOM »
https://forums.nicoclub.com/shift-bodom-u20648.html
Fri Jun 03, 2005 10:35 pm
hey all, swapped in a 96 longblock into my 93 about 3 months ago, and i have the 96 manifolds and fuel rail + injectors. i took off my throttle body and cleaned it up a bit, looks nice. i was wondering, should i port it, polish the inside (dont know if it would hurt performance), and can i even fit it onto my car? i dont know if the TPS connectors are different from my 93 plugs. can someone confirm this? also, is there any benefit to putting in the 96 fuel rail and/or injectors on my engine, or should i just sell those? is there any advantage to using the 96 headers? i already know there's no hope of using the 96 intake, since a lot of the connectors are totally different. i already swapped in the old cams, so thats taken care of.
my main concern is the throttle body. would any of what i mentioned above be beneficial? oh, the throttle plate..or butterfly, if you will...can that be removed and cleaned with brasso or something similar, or should i just stick with the throttle body cleaner?
very interested to hear what everyone comes up with.
