AZ89two4Tsx »
https://forums.nicoclub.com/az89two4tsx-u91596.html
Sat May 22, 2010 9:02 pm
I've got a good old single slammer and there is quite a bit of vibration at low rpm's. Most of it is a little above idle, like just over 1K. It shakes like a mofo if it it's the "sweet spot" if you will.
I've checked the mounts and they seem fine. And it really doesn't move much over higher rpm's, just at that point. Also, I took A/C compressor out recently and it didn't seem to have an effect, so I'm kinda stumped.
Any ideas? I was just thinking of getting a torque damper but seems kinda like I'd just be covering up the problem.
