Alright I don't have a Nissan I have a Ford, built in 1963, sorry. I'm looking at using s13 brake master cylinder and booster though, it's the only thing I can think of that has a big bore and small package.
I need power brakes and I don't want to use $375 of Wilwood Brakes stuff, and I don't want to use Geo Metro stuff.
The problem I have with my Falcon is the engine bay is meant for no power brakes, a single reservoir master cylinder for 4 drum brakes, and a straight six. Now that I have a v8 and 4 discs I need more fluid (bigger bore) and I need power brakes because I just can't handle manual brakes with 4 big discs for driving around town. It's been manual brakes for 55 years, it's easy with drums but I put discs on the front and it got about twice as hard, and now that I'm putting discs on the back too it's probably going to be a lot harder than it already is and it won't be pleasant to drive around town, especially since sometimes my little sister or mom drive it.
So in my searches for small brake setups I found a Datsun510 site that suggested s13 parts so that's what I'm after now.
http://www.fordfalcon2000.com/restorati ... rakes2.JPG This is a Geo Metro setup in a 63 Falcon, not much room at all. It's about 9.5 to 10 inches between the firewall and the shock tower. The export brace is going to have to go if I want power brakes that aren't Geo parts. And I'm fine with fabbing up a tubular export brace instead of that stamped steel one.
Anyways my questions are:
1: If there's a simplish robust way to make a remote reservoir on an s13 master cylinder so I don't have to remove the export brace? I'd also be up to doing it on an s14 master cylinder since
the proportioning valve is separate as far as I understand? But the s14 only had a 15/16" bore available I think, is that true?
2: What is the shortest/smallest brake booster that an s13/z32 master cylinder can bolt up to without an adapter?
3: Are all non-abs s13's a 15/16" bore? Are most z32's the 16/16" bore? Which z32's have the 17/16" bore, the turbo ones or something?
4: Can the proportioning valve be easily fully deleted in the s13 master cylinder so I can use my own inline adjustable valve?
5: I understand the sentra brake boosters can be used with an s13 master cylinder and that can help with avoiding the driver side valve cover and the clutch cable.
6:
And most of all I'd really love measurements of as much stuff as you guys can measure if you don't mind.
measurements like
1: Total length of s13/z32 master cylinder, s14 too if that's much different or if I decide to go that route.
2: Length from mounting flange of master cylinder to the front of the fluid reservoir where it may or may not run into the export brace
3: Depth/length and diameter of various brake boosters including b12/b13/b14 sentra boosters. Abs and non-abs I'm happy to get any info y'all have on this.
Anyways sorry for all the questions but I'm trying to get this car done and since the Geo is only 13/16" and it says Geo on it I'm not interested in it.
