Lots of body roll... (s14)
GODCHSR
Car: 1996 Nissan 240sx
OK, my only suspension modifications are KYB AGX Adjustable shocks and H&R Sport Springs.
I'm looking for some common sense answers here... What is the weak links on cornering with our cars?
I ask this because when I go into corners hard there is a massive amount of roll... SO MUCH that the car will fully sway hard in one direction without any tire squeal TILL the body 'hits' it's full sway. It makes it slightly unpredictable when attempting drifiting because you never can be certain when the tires will break because the body weight is lagging behind.(If this doesn't make any sense I apologize but I don't know all the cornering terms as of yet)
Modified by GODCHSR at 4:29 PM 8/2/2009
240sxka-t
Car: 94 sentra ga16 coupe
strut tower bars help.
sway bars?
since you already have coilovers
240dx
Car: '97 Nissan 240SX LE
get strut bars. There cheap and very efficient
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
If you have body roll then you need a sway bar upgrade.
Strut bars won't help very much with body roll.
PapaSmurf2k3
Site Admin
Look for sway bars or damaged sway bar end links. If your end links are damaged/separated, you'll get massive body roll.
S14toRPS13
Everyone's already mention sway bars, but what spring rates do you have on your coilovers? I have 8 k up front and 6 k in the rear and I don't get very much bodyroll at all.
Modified by S14toRPS13 at 3:52 PM 8/2/2009
mrgrape
Car: s14
SWAY BAR #1SUBFRAME BUSHING #2
GODCHSR
OK, so swaybar upgrades FTW.
GODCHSR
S14toRPS13 wrote:Everyone's already mention sway bars, but what spring rates do you have on your coilovers? I have 8 k up front and 6 k in the rear and I don't get very much bodyroll at all.
I am not sure I'll have to research that one.
GODCHSR
I modified my original post... I do NOT have coilovers. I have adjustable shocks and sport springs.
Sorry for the misinformation.
S14toRPS13
GODCHSR wrote:I modified my original post... I do NOT have coilovers. I have adjustable shocks and sport springs.
THere you go then. When I had Eibach sportlines, I was still getting lots of bodyroll. Both on my fastback and on my S14. It probably has a lot to do with your springs then.
mrgrape
Car: s14
yeah if u dont have coilovers i highly reccomend it, stop being a p**** if i may say so and just slap some on.its like a whole new feeling.ive driven cars with aftermarket shocks and springs and compared to coils they are nothing!
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
killernoodle wrote:If you have body roll then you need a sway bar upgrade.
(You're not stupid dude)
GODCHSR
I will definitely be upgrading my suspension. To be honest its a good setup but since I'll be doing drag racing specifically and not using this as a DD much longer I figure I should go for a specific setup.
I planned on up grading the entire rear suspension but I think I'll start with the sway bars.
Modified by GODCHSR at 2:13 PM 8/3/2009
maryjane
sway bars are a great upgrade!
strut bars are a cheap/ ok upgrade!hope this helps
