squirrl22 »
https://forums.nicoclub.com/squirrl22-u87161.html
Mon Feb 04, 2008 6:11 am
Just got the s420det blacktop running in the 95s14. LOTS OF BLUE SMOKE!It smokes on idle, and smokes on acceleration. I let it idle for 5 minutes, than drove it for 6-7 minutes, still plenty of smoke. I have no idea how long the engine was warehoused before I got it. It came from Japan w less than 50k miles. Pulled the plugs, there is a lot of oil on cyl #4 plug, the rest look great.I did a compression test - I get 150 on cyl #4, 155PSI on the other 3 cylinders.Pulled the exaust manifold- oil seeping from cylinder #4 exaust port. No oil in the radiator.
With oil on the spark plug, I know I have a problem w cyl 4- but could this much oil be coming from just bad valve seals? Normally, if it is a bad valve seal, you get smoke on idle and it goes away on acceleration. If bad rings, smoke on acceleration, but not at idle. I smoke no matter what.
Maybe a combination of things?
