Lots of aftermarket brake rotor/pad kits on ebay...
truckmen
Car: 2013 Nissan Xterra
...and the entire 4-wheel kit can be had for around $200, including rotors and pad (but not e-brake shoes).
My question is, does this sound reasonable for these items?
The rotors are advertised as slotted and drilled with holes chamfered. also, the pads are ceramic.
I also found a set of front calipers for <$100.
I didn't post the names in case it is against forum policy but can of it's OK. I am just worried about buying junk.
Thanks.
Truckmen
yodawill2000
Car: 94 Infiniti J30
Stuff that cheap is usually way less quality than OEM.What brand name ?? Im sure someone here will know about them,
truckmen
Hi again, Yoda,here are the links to the rotor/pad kits:
http://cgi.ebay.com/ebaymotors...ories
...and...
and one more:
driverdriver
Car: NICO's longtime resident Canuck!!!
The J is heavy car, the weight applied with brake force easily warps rotors. My advice(gleaned form being on this forums for many years) is to go with Nissan OEM, Napa premium or high end like Brembo or Powerstop. The same for the pads. The best stuff is ceramic or semi ceramic, get Napa premiums, EBC, Hawk, Akebono or Brembo's.
truckmen
Hi driverdriver,
Thanks.Yes, I think the J is pushing 3900lbs. OK, I will give Napa a call and price some stuff.
