LOSt TORQUE, Exhaust
IlIkEmYz
Car: 06 Z
hey i just go a custom exhaust 2.5 piping with the megan racing n1 muffler.
im not sure if i lost any torque, but i think i did im not sure.
what do you guys think
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
if thats all you did, you wouldnt be able to feel it, its miniscule gains/losses
MyCarIsWack
Car: stuff
I think the bigger the exhuast, the more hp but less torque
the smaller it is the more torquethere is this thing u can get to go in ur exhuast
that is small at lower speeds, and opens up as u increase speed, to maximize torque and HP
IlIkEmYz
Car: 06 Z
what's that thing any link???
SHIFTrl240
even if this is the case we are only talking maybe 2-3 horses/ftlbs if you have no other mods. that kind of change is not recognisable from your butt dyno
its just in your head :)
MyCarIsWack
Car: stuff
this is very true, but eh
when ur at so little already u tend to want to keep every last bit lol
IlIkEmYz
Car: 06 Z
MyCarIsWack wrote:this is very true, but eh
That is so true, you read my unconcious mind
MyCarIsWack
Car: stuff
lmao, there so many things u can do to ur car for cheap or freeto get lil hp gains here and theredo some research read the FAQ's and automotiveforums.com has a lot of good info too
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
MyCarIsWack wrote:I think the bigger the exhuast, the more hp but less torque
The most famous adjustable muffler would probably be the Supertrapp muffler, but it is adjustable by installing/ removing baffles, so it's not "active" like you discribe.
The other is a new type of muffler made by APEXi, called the PS Revolution. It has a exhaust pressure activated valve in it that opens with the amount of flow. My guess is it's way expensive.
SilviaS14KA24DE
Car: Doriftu
well that one that automatically opens and closes i believe is an A'Pexi. it's a very new product from them.
C-Kwik
Not necessarily. It depends on a lot of factors. A larger exhaust tends to increase torque at higher RPM's while potentially losing some low RPM torque. To increase HP at a certain RPM, you must increase torque at that RPM. So depending on what the torque curve looks like and how the larger exhaust affects the motor, you may be able toi increase torque and HP.
